Hi, I've updated the datashape on which is built an infotable called "myInfotable" that contains data (inside a thing), the update consists in adding a column.
I saved and even restarted the thing, but i can't see the new field i added from the datashape, but if i create a new property (on the same thing) for i.e. "myInfotable2" and populate with data, i can see the new field properly!
Since I can't delete the previous property because it stores important data, how can i fix this?
I found a workaround and this is:
- Create a service on the template or thing that runs this code:
me.appointments_list.AddField({
"name": "appointment_guests",
"baseType": "STRING"
- Run it on the things and the new fields will appear even on the existent infotable properties!
