Can we connect to Thingworx platform using TCP/IP Protocol?
RohitKumar_Jais
I want to connect to Thingworx platform through Java simulator using TCP/IP protocol instead of Web Socket protocol. Is there any way to connect Thingworx application using TCP/IP protocol?
3 REPLIES 3
ankigupta
(To:RohitKumar_Jais)
Hi Rohit Kumar Jaiswal​,
Have you checked TCP Extension: https://marketplace.thingworx.com/Items/tcp-extension
I think it might be helpful in your case.
Ankit Gupta
ankigupta
(To:ankigupta)
Hi, Ankit Gupta
This guide explain 1:1 connect
if device or sensor has many than 1, how can i set thingworx to connect 1:N?
should i use other tcp/ip socket program?
