Can we create custom login page without providing org name in Thingworx?
vvaidya
Hi All,
I want to create a custom login page which redirects my user to a mashup on successful authentication. I want to handle the invalid credentials in the same custom page. (Should not redirect to form login page)
Aanjan Ravi​@
Any idea.
Thanks in Advance!
Vishal Vaidya
7 REPLIES 7
Aanjan
(To:vvaidya)
Vishal, you can probably still use the FormLogin's html structure, but create your own custom page around it. Please take a look at the html page source of a FormLogin page to see what loads, and where the credentials are getting pushed to.
aelgov
(To:Aanjan)
Can you please provide more information?
PaiChung
22-Sapphire I
(To:aelgov)
Here is a jsp example
<%@page contentType="text/html" pageEncoding="UTF-8"%>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
<meta http-equiv="Expires" content="-1">
<meta http-equiv="Pragma" content="no-cache">
<meta http-equiv="Cache-Control" content="no-cache, no-store, must-revalidate">
<link rel="stylesheet" href="/Thingworx/css/thingworx.css" type="text/css" media="screen" charset="utf-8" />
<title>Thingworx Form-Based Login</title>
<script type="text/javascript">
function GoToMenu(){
  window.open("/Thingworx/ThingworxMain.html", "ThingWorx Menu","",true);
</script>
</head>
<body>
  <div class="main-wrapper">
  <div class="header-wrapper">
  <div class="header">
  <div class="top-links">
  <a href="/Thingworx/ThingworxPasswordChange.jsp" class="toplink">Change Password</a> |
  <a style="text-decoration: underline;cursor:pointer" onclick="invokeLogoutService()" class="toplink">Log Out</a>
  </div>
  <a href="/Thingworx/ThingworxMain.html" class="logo"></a>
  <span class="dashboard-title">
  <span class="welcome-text">Welcome to ThingWorx</span>
  </span>
  </div>
  </div>
  <div class="content-wrapper password-change">
  <div class="content">
  <FORM METHOD="POST" ACTION="action-login">
             String msg = (String)session.getAttribute("loginErrorMessage");
             if (msg != null) {
                     out.println("<h1>There was an error in the login process: " + msg + "</h1><h1>Please try again</h1>");
             else {
              out.println("<h1>Please enter your username and password</h1>");
             String redirect = (String)session.getAttribute("redirectUri");
             if (redirect == null || redirect.isEmpty()){
              out.println("<INPUT TYPE=\"hidden\" NAME=\"redirectUri\" VALUE=\"/Thingworx/IDE/Runtime/index.html#target=ThingWorxCommunity&mashup=TWCommHome\"/>");
             else if (redirect.contains("action-login")) {
             else {
              out.println("<INPUT TYPE=\"hidden\" NAME=\"redirectUri\" VALUE=\"" + redirect + "\"/>");
  <TABLE>
  <TR  class="current-password"><TD class="form-label">
  <label>Name:</label>
  </TD>
  <TD>
  <INPUT class="form-field" id="thingworx-form-userid" NAME="thingworx-form-userid" VALUE=""/>
  </TD>
  </TR>
  <TR><TD class="form-label">
  <label>Password:</label>
  </TD>
  <TD>
  <INPUT class="form-field" id="thingworx-form-password" TYPE="PASSWORD" NAME="thingworx-form-password" VALUE=""/>
  </TD>
  </TR>
  </TABLE>
  <INPUT TYPE="submit" VALUE="Login"/>
  <INPUT TYPE="hidden" NAME="x-thingworx-session" VALUE="true"/>
  <INPUT type="button" onclick="GoToMenu()" value="Cancel"/>
  </FORM>
  </div>
  </div>
  <div class="footer">
  <span class="footer-text">Copyright &copy; 2011 ThingWorx. All rights reserved.  Version: 2.0.0</span>
  </div>
  </div>
</body>
</html>
aelgov
(To:PaiChung)
Thanks.
What do I do with it?
PaiChung
22-Sapphire I
(To:aelgov)
Create your own webpage (html) that you can place anywhere to use as the landing page with this jsp form on it and that then launches them into a desired Thingworx mashup using their provided Name and Password
aelgov
(To:PaiChung)
Create your own webpage (html) - Done
How do I lunch it into mashup?
atahri
(To:aelgov)
Hello, I have the same problem. Can you  post more information about how you did it.
