Hi All,
We are planning to install TWX 9.2 in Azure with Azure Postgres as persistence providers. Is it supported?
If not , what others Database is supported for TWX 9.2 version in Azure. Kindly share any link for more information.
HI @koushal.
Azure PostgreSQL is not a supported DBMS. Here is a link to the compatibility matrix for ThingWorx 9.2. As an alternative, you can set up your Azure VM and install PostgreSQL, but it is not something Microsoft would manage.
--Sharon
AzureSQL is supported (https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Composer/DataStorage/PersistenceProviders/using_azure_sql_server_as_the_persistence_provider.html)
I've also installed on Azure Postgres without issue but I'm not sure if it's officially supported.
-Nick
HI @koushal.
--Sharon
