Hello everyone,
Our ThingWorx configured with SSO configuration using CAS(PingFederate). Now, I would like to login with other user, Can we login ?
Could please anyone send the possibilities to login?
madhu
Is your configuration having SSO with AD?
If yes, then the user needs to be defined in the AD then you be able to login to the ThingWorx using that user
Hi @mnalla,
If you have configured PingFederate SSO with ADFS, all the users will be fetched from ADFS only. You won't be able to use any other default authenticator.
BR,
Harsh Selarka
Hi @mnalla,
Did the responses provided helped you with the question you had? If yes, please select the 'Accept as Solution' to close this thread. If these didn't helped you and if you have any further questions, please post it.
BR,
Harsh
