I want to create a link to a different use case Mashup deployed in a Global server. My application sits in a local server. Is it possible to bypass the login popup and open the mashup directly using links or navigation from the local server application?
The one way you could do this is by having an app key in the URL for auth. You'll have to enable that in the platform subsettings and then you can use thingworx-x-session=true&appKey= ...
see: https://www.ptc.com/en/support/article/CS227935
Hi, Thanks for your response @PaiChung
I dont have any users/customer profiles defined in Thingworx. It basically an LDAP connection or maybe a SSO in the future. In that case can i group few users only to have that access for the application key to access the link or something like that. I believe we have the user profile details in database and credentials verification via a REST service.
The approach I provided would allow a user to see Thingworx mashups with a generic account without having to log in.
I'm not an expert with SSO but maybe you can accomplish the redirect without auth necessity using SSO
Sure Thanks again @PaiChung
One more questions is that, in the article you've shared, its mentioned as applies to only till version 8.5
Will it still work for 9.0 and higher versions in the future?
I haven't actually checked if this option is still available in 9.0
I would think it is still possible one way or another.
Hi @SK_9531327.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
