Can we refine the Analytics model?
amulay
8-Gravel
In would like to refine the analytics model once it's built for some data. Whether it is possible and how I can do it?
It means the models will learn from incoming new data and learn and get refined.
mgoel
(To:amulay)
@amulay Thank you for opening this thread on Community.
Could you please clarify, Have you created a predictive model ? and you want to retrain the same?
As per my understanding you can retrain the same model in analytics builder with only same data. But if you want to add additional data you can got to data set, Upload additional data to a particular data-set. Then create model with the same.
Regards-Mohit
2 REPLIES 2
mgoel
(To:amulay)
Regards-Mohit
amulay
8-Gravel
(To:mgoel)
Yes, I have created the predictive model and was trying to retrain the same with new data.
Will follow the same workflow as you mentioned!
