Cannot find the extension files needed for Thingoworx and Azure connection
dsengupta-21
2-Guest
I want to download the ConnectionServicesExtension-1.0.0.zip for ThingWorx Azure connection. But I cannot find the zip file in the link provided.
I am following this tutorial to do it ThingWorx Azure Connector Installation and Operations Guide (​https://community.thingworx.com/external-link.jspa?url=http://support.ptc.com/WCMS/files/171022/en/ThingWorx_Azure_Conne…).
Please tell me where can I find that...
Thank you...
ankigupta
(To:dsengupta-21)
Hi Dipika Sengupta​,
Download the ThingWorx AWS IoT Connector from https://marketplace.thingworx.com/Items/aws-iot-connector
Unzip the download and find the ConnectionServicesExtension-X.X.X.zip in the extension folder.
I hope it helps.
ankigupta
(To:dsengupta-21)
I hope it helps.
Hello Ankit,
I need to connect Azure. Not AWS. Would it be the same?
ankigupta
(To:dsengupta-21)
ConnectionServicesExtension is same.
Okay Ankit... Thank you
ankigupta
(To:dsengupta-21)
Dipika Sengupta​,
If this issue is resolved; please mark correct and helpful posts to let other members know this Thread has a solution.
