ThingFlow keep hanging when launching it , I've checked the article https://www.ptc.com/en/support/article/CS323653
, but still doesn't help. could be any other reason ?
ThingWorx 9.1.0
OS: REHL 8.2
Sean
Check if below configurations are correct,
Note: Before making any changes, review other software's running on your system for any impact by below settings
I've reviewed the steps you suggested , but still cannot launch flow .
I found more logs may related to the request: currentuser:
Hi @seanccc.
If you have not found a solution, I suggest we open a case. I will be happy to open one on your behalf with your approval.
--Sharon
