Cannot start thingworx 7.4; error with JDBC connection
nsridhar-2
6-Contributor
I have installed thingworx 7.4 (fresh installation) but its not UP and running. Below are the details of my environment,
Server : Windows Server 2012 R2 (VM)
thingworx 7.4
PostgreSQL 9.4.12
Apache Tomcat/8.0.38
Java 1.8 92 b14
Once installed and start the thingworx from Internet Explorer, it does not ask for any Log in, there is a blank page shown without any errors. Below is the screenshot.
The application log file from thingworxstorage
2017-05-26 11:43:58.019+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-10] Could not handle request
2017-05-26 11:44:05.285+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-11] Could not handle request
2017-05-26 11:44:06.082+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-12] Could not handle request
2017-05-26 11:44:06.301+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-13] Could not handle request
2017-05-26 11:44:06.488+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-14] Could not handle request
2017-05-26 11:44:06.660+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-15] Could not handle request
2017-05-26 11:44:06.848+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-16] Could not handle request
2017-05-26 11:44:07.035+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: SuperUser] [S: ] [T: http-nio-80-exec-7] Could not handle request
2017-05-26 11:44:07.207+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-8] Could not handle request
2017-05-26 11:44:07.395+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-9] Could not handle request
2017-05-26 11:44:07.551+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-10] Could not handle request
2017-05-26 11:44:07.738+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-11] Could not handle request
2017-05-26 11:52:36.581+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-14] Could not handle request
Same application log file from yesterday is as below,
2017-05-25 20:06:35.100+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] [message: Unable to initialize and start system: Connections could not be acquired from the underlying database!]
The entries from PostgreSQL log is as below.
2017-05-25 19:43:24 IST LOG:  database system was shut down at 2017-05-25 19:43:22 IST
2017-05-25 19:43:24 IST LOG:  MultiXact member wraparound protections are now enabled
2017-05-25 19:43:24 IST LOG:  database system is ready to accept connections
2017-05-25 19:43:24 IST LOG:  autovacuum launcher started
2017-05-25 19:48:53 IST FATAL:  password authentication failed for user "twadmin"
2017-05-25 19:48:53 IST DETAIL:  Connection matched pg_hba.conf line 80: "host    all             all             127.0.0.1/32            md5"
Below is the screenshot of the PostgreSQL,
All the thingworxstorage, thingworzbackstorage, thingworxplatform are all places directly under E:/ and it is shared with the all the users.
Any help is greatly appreciated.
Regards
Naveen
12 REPLIES 12
AnnaAn
(To:nsridhar-2)
Hi Naveen,
Could you share your platform-settings.json?
Does your PostgreSQL installed on same server to ThingWorx?
Br,
Anna
Please check your password for db in platform-setting.json .
very clear in logs :
pagrawal-2
2-Explorer
(To:AnnaAn)
Hi Anna An,
I am facing also same problem with MSSQL........
"https://community.thingworx.com/thread/41733?q=Thingworx%207.4"
Please once this page for my query.....
nsridhar-2
6-Contributor
(To:AnnaAn)
Yes I have PostgreSQL installed on the same server.
Below is the content of the json file.
"PersistenceProviderPackageConfigs": {
  "PostgresPersistenceProviderPackage": {
   "ConnectionInformation": {
    "jdbcUrl": "jdbc:postgresql://localhost:5432/thingworx",
    "password": "twadmin",
    "username": "twadmin"
Hi Ravi, password is the same. I have posted the contents for json file above. I just cant find any difference in the username and password.
Should we not keep the username and password same?
Regards
Naveen
I also hava this error :
My platform-setting.json  is
"driverClass": "org.postgresql.Driver",
"password": "password",
error code :
java.lang.Exception: Unable to initialize and start system: Connections could not be acquired from the underlying database!
supandey
(To:hzhaodong)
Hi Huang, is this a fresh installation of ThingWorx or was this working previously? Are you able to connect to ThingWorx database running on PostgreSQL via tool like PgAdmin III tool?
yes I can connect to ThingWorx database running on PgAdmin tool.
cmorfin
(To:hzhaodong)
Huang ZhaoDong
Can you check that the username and password you use to connect to postgres through pgAdmin are the same as in the paltform-setting.json, that is username twadmin, password: password ... if not please update the platform-settings.json
Kind regards
Christophe
I check username and password is OK , but tomcat error JDBC connection.
I had this same problem.  Everything was setup correctly and the platform-settings.json file was perfect but I still got the message:  password authentication failed for user "twadmin".  The problem is it is not seeing the platform-settings.json file.  I set the THINGWORX_PLATFORM_SETTINGS environment variable to the correct folder, restarted Tomcat, and all worked correctly.   Errors were gone and I got the logon prompt.
I add this tidbit because no one else had mentioned it yet.
Good luck.  Robert.
