I have installed thingworx 7.4 (fresh installation) but its not UP and running. Below are the details of my environment,
Server : Windows Server 2012 R2 (VM)
thingworx 7.4
PostgreSQL 9.4.12
2017-05-26 11:43:58.019+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-10] Could not handle request
2017-05-26 11:44:05.285+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-11] Could not handle request
2017-05-26 11:44:06.082+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-12] Could not handle request
2017-05-26 11:44:06.301+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-13] Could not handle request
2017-05-26 11:44:06.488+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-14] Could not handle request
2017-05-26 11:44:06.660+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-15] Could not handle request
2017-05-26 11:44:06.848+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-16] Could not handle request
2017-05-26 11:44:07.035+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: SuperUser] [S: ] [T: http-nio-80-exec-7] Could not handle request
2017-05-26 11:44:07.207+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-8] Could not handle request
2017-05-26 11:44:07.395+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-9] Could not handle request
2017-05-26 11:44:07.551+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-10] Could not handle request
2017-05-26 11:44:07.738+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-11] Could not handle request
2017-05-26 11:52:36.581+0530 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-14] Could not handle request
Same application log file from yesterday is as below,
2017-05-25 20:06:35.100+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] [message: Unable to initialize and start system: Connections could not be acquired from the underlying database!]
The entries from PostgreSQL log is as below.
2017-05-25 19:43:24 IST LOG: database system was shut down at 2017-05-25 19:43:22 IST
2017-05-25 19:43:24 IST LOG: MultiXact member wraparound protections are now enabled
2017-05-25 19:43:24 IST LOG: database system is ready to accept connections
2017-05-25 19:43:24 IST LOG: autovacuum launcher started
2017-05-25 19:48:53 IST FATAL: password authentication failed for user "twadmin"
2017-05-25 19:48:53 IST DETAIL: Connection matched pg_hba.conf line 80: "host all all 127.0.0.1/32 md5"
Below is the screenshot of the PostgreSQL,
All the thingworxstorage, thingworzbackstorage, thingworxplatform are all places directly under E:/ and it is shared with the all the users.
Any help is greatly appreciated.
Regards
Naveen
Hi Naveen,
Could you share your platform-settings.json?
Does your PostgreSQL installed on same server to ThingWorx?
Br,
Anna
Please check your password for db in platform-setting.json .
very clear in logs :
Hi Anna An,
I am facing also same problem with MSSQL........
"https://community.thingworx.com/thread/41733?q=Thingworx%207.4"
Please once this page for my query.....
Yes I have PostgreSQL installed on the same server.
Below is the content of the json file.
"PersistenceProviderPackageConfigs": {
"PostgresPersistenceProviderPackage": {
"ConnectionInformation": {
"jdbcUrl": "jdbc:postgresql://localhost:5432/thingworx",
"password": "twadmin",
"username": "twadmin"
Hi Ravi, password is the same. I have posted the contents for json file above. I just cant find any difference in the username and password.
Should we not keep the username and password same?
Regards
Naveen
I also hava this error :
My platform-setting.json is
"driverClass": "org.postgresql.Driver",
"password": "password",
error code :
java.lang.Exception: Unable to initialize and start system: Connections could not be acquired from the underlying database!
Hi Huang, is this a fresh installation of ThingWorx or was this working previously? Are you able to connect to ThingWorx database running on PostgreSQL via tool like PgAdmin III tool?
yes I can connect to ThingWorx database running on PgAdmin tool.
Huang ZhaoDong
Can you check that the username and password you use to connect to postgres through pgAdmin are the same as in the paltform-setting.json, that is username twadmin, password: password ... if not please update the platform-settings.json
Kind regards
Christophe
I check username and password is OK , but tomcat error JDBC connection.
I had this same problem. Everything was setup correctly and the platform-settings.json file was perfect but I still got the message: password authentication failed for user "twadmin". The problem is it is not seeing the platform-settings.json file. I set the THINGWORX_PLATFORM_SETTINGS environment variable to the correct folder, restarted Tomcat, and all worked correctly. Errors were gone and I got the logon prompt.
I add this tidbit because no one else had mentioned it yet.
Good luck. Robert.
