Friends,
Any idea on implementing cascading attributes feature in Thingworx?
Thanks Sharon,
I am able to develop the same feature in thingworx navigate using data tables.
thanks
Naga.
Hi @ninaganti.
I assume you're referring to the cascading attributes feature available in Windchill, correct? If so, you should be able to code the same behavior in ThingWorx, but I don't think it's available out of the box.
However, you can post this request on the ThingWorx Ideas board. This will allow other community members to be able to vote for it, which will increase the possibility that it will be considered for a future release.
--Sharon
Thanks Sharon,
thanks
Naga.
Hi @ninaganti.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
