We are troubleshooting an issue impacting community login, and it may be intermittently unavailable. Sorry for any inconvenience.
So after I have created several things I would like to change the avatar. I can go into the thing properties, point the avatar to a new location, and have the avatar displaying in the section when I am in edit mode of the thing. However, if I go back to my mashup and pull the data for my thing, the old avatar is still in place. Am I missing something? Is this a bug? I was just wondering if anyone else has had this issue. Also, I changed the thing template avatar to the same new image. Thanks for the help!
Usually this is due to a browser cache, I've experienced sometimes problems with avatars without reloading the Composer, it doesn't makes much sense but...
Just reload with the Shift key pressed both tabs ( Composer and Mashup )
Carles.
That was exactly it! Thank you!
