Can I change a binding like in manage bindings menu through script? and if I can, how so ?
Hi @GV_11098078 ,
In thing level you can find the 'SetLocalPropertyBinding,SetRemotePropertyBinding,RemoveLocalPropertyBinding,RemoveRemotePropertyBinding' with the help of these Binding Servcies you can easily manage the bindings to property in script level.
Thanks & Regards,
Arun C
Hi @GV_11098078 ,
Thanks & Regards,
Arun C
Hi @GV_11098078 ,
It appears that Arun's reply answers your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
