I have textbox in mashup. I need to change the background color from the service.
How to do this. Pls help
Raju
TextBos doesn't have State Based styles, then Out of the box you can't do it.
But maybe you can set a transparent background, and set behind the TextBox a ValueDisplay Widget which has StateBased Styles and change the color.
