I have two mashups, in the first one I have a grid with a history of my properties
mashup1
In the second one I have the details for each thing
mashup2
is it possible that, if I click on a Row of the grid in mashup1, it links me to mashup2 on the thing tab corresponding to the row I've clicked?
(To explain myself better: In the image, on the second Row, there is thing DS-TH_5, I would like that if I click on second row, I'll be linked to mashup2 on the tab of DS-TH_5)
You should use "Selected Row" from the service which returns table on first Grid, to bind the corresponding data to the other mashup
Here is documentation on how to use mashup parameters, which is what you need in order to do as Carles is suggesting, I believe: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS187026&lang=en&source=snippet
