Changing Panel background based on an input
the_incapit
6-Contributor
I am implementing a workaround for a custom toastr extension, Iam using a Mashup as modal popup with animations using custom css to display the toastr.
I need to change the panel/Mashup color based on an input like to show green when its a success message and red when its a warning. The Input need to passed from another mashup to the toastr mashup.
Toastr mashup contains a panel and label widget., I am using thingworx version 8.5
Can anyone please point out a way to change the panel color using a custom input?
1 ACCEPTED SOLUTION
PaiChung
22-Sapphire I
(To:the_incapit)
Not too certain how to affect the panel background potentially css? I imagine you've tried that.
Could make it a dynamic mashup so if you had 3 colors, you have 3 mashups that swap based on value.
I know there used to be a custom 'layer' widget which allowed you to overlay two responsive mashups that would work as well, but I'm not sure if that is available anywhere.
2 REPLIES 2
PaiChung
22-Sapphire I
(To:the_incapit)
the_incapit
6-Contributor
(To:PaiChung)
Thank You, I will Try out the same
