I am working on changing the grid widget from the Thingworx default code.
My goal its to display the grid but without the top black header(remove the header row), I only want to display the information below that row.
I found out that the HTML that generates the header in the runtime.js file appears like this:
this.buildHeaderRowHtml = function(infoTableDataShape) {
var html = '';
html +=
'<thead>';
if( thisWidget.getProperty('ShowAllColumns') === true ) {
var renderer = TW.Renderer.DEFAULT;
for (var fieldName in infoTableDataShape) {
html += '<th><div class="print-header-cell">' + fieldName + '</div></th>'
} else {
var colFormat = thisWidget.getProperty('ColumnFormat');
if (colFormat !== undefined && colModel.length === 0) {
// translate our internal 'ColumnFormat' to the dhtmlxgrid's idea of a column model
for (var i = 0; i < colFormat.formatInfo.length; i++) {
var col = colFormat.formatInfo;
var thisWidth = 100;
if (col.Width === 'auto') {
thisWidth = undefined;
} else {
thisWidth = col.Width;
colModel.push({ name: col.FieldName, label: TW.Runtime.convertLocalizableString(col.Title), width: thisWidth, align: col.Align, formatoptions: col.FormatOptions, col: col });
_.each(colModel,function(col) {
html += '<th><div class="print-header-cell">' + col.label + '</div></th>'
html +=
'</thead>';
return html;
Anyone here that explored the default code of the Grid Widget and knows how to disable the header or just the way to change the code to do what I want?
Thank you.
Thank you for your answer.
I manage to get my widget working by adding the setNoHeader(bool) method to the init function of the runtime.js file
newgrid = new dhtmlXGridObject(domElementIdOfnewgrid);
newgrid.fontWidth = headerFontWidth;
newgrid.enableKeyboardSupport(true);
newgrid._colModel = colModel;
newgrid.setImagePath("/Thingworx/Common/dhtmlxgrid/codebase/imgs/");
newgrid.setHeader(gridHeader);
newgrid.setNoHeader(true);
newgrid.setInitWidths(gridInitWidths);
newgrid.setColAlign(gridColAlign);
if (gridColTypes.length > 0) {
newgrid.setColTypes(gridColTypes);
João, you could possibly create this as your own custom extension and import that instead.
