Checking where certain properties are used
Janicen
Hi community,
I would like to check if two specific properties are being used / referenced in any subscription on any entity.
I tried using getWhereUsed but this gives me an empty result when I view the result as a table.
Is what I am trying to accomplish possible on thingworx?
Rocko
(To:Janicen)
Have you enable the "Referenced By" in the RelationshipSubsystem? You should be able to use the View Relationships>Referenced By mashup then on the ThingEditor.
Rocko
(To:Janicen)
