I would like to filter the InfoTable returned by a SQL query using a ChipBasedFilter widget and return it directly to an Advanced Grid.
Is there a way to achieve this without creating an intermediate service? I have several mashups with very different requirements and would rather not write a separate service for each one.
Thingworx V9.2
Is there a more detailed description for this? I've never executed such calls directly from the MashUp before.
Basically, it works. However, it doesn't recognize the underlying DataShape. This could be because the service that returns the data is SQL-based.
I did it with a wraped Service now
Thanks for your help.
