Choose specific row from infotable to apply to LED Display
Visitor
I have a service that runs and creates an infotable. I want to apply the value of a Field to a LED Display but only use the 3rd row value. Is there a way to do this without having to create an entirely new service that runs the original service and then returns the 3rd row value of the Field I am looking for?
Tags (2)
Currently there is no method for binding a widget to a specific row/field in an InfoTable result. As you've indicated, a second service could be used to extract the data needed but depending on the use case you might just reduce InfoTable result in the original service to only the desired row/record or perhaps sort the result so that the desired record is the first (the default record used when binding).
