Circular regions on maps
msutton
7-Bedrock
Hi Everyone.
I have been using the google maps widget for displaying simple location data, markers and paths on the google maps widget. Next what i want to do is have an over lay to this that places circular regions over the location markers who's size is dependant on one of my properties. I'm not sure if this would be easiest to do using a region who's centre is defined by the location marker, radius from the property and then calculate the geofence ( i think this could work out quite time consuming) Or i use the Marker as my circle and instead of having the standard marker i have one who's size changes depending on the input property. I'm happy to use Open StreetMaps or google maps as i have seen an example in open street maps (not on thingworx) that coloured the path green to red based on CO2.
Any help or pointers would be much appreciated. Hoping that someone has already cracked something similar to this.
Thanks Matt
2 REPLIES 2
ankigupta
(To:msutton)
Hi Matthew Sutton​,
Are you looking for something like: Re: Animation In Thingworx?
It would be great if you can share any screenshot (if available) of your requirement
Ankit Gupta
Hi Ankit
Sorry i don't have any images. I just did some poking around and i found a useful document on creating a region and i think this is the way i want to go. https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS225480 In addition to this i will create the region using the create circular geofence code snippet. I have written this into a script but it does for some reason not show on the map even though it is using the same fundamental process as the manual region creation. see my code below. I have output the geofence infotable and it looks correct and works as it should. i have even taken these values and input them manually into the update data table entries service and this worked as well. Maybe you can spot a problem?
Thanks Matt
// location:LOCATION
var location = new Object();
location.latitude = 50.00;
location.longitude = -0.39;
location.elevation = 0;
location.units = "WGS84";
// createCircularGeoFence(location:LOCATION,radius:NUMBER,units:STRING,resolution:INTEGER):INFOTABLE
var geofence = createCircularGeoFence(location, 1, "km", 10);
var values = me.CreateValues();
values.LocationRegion = geofence; //INFOTABLE
values.ID = 1; //NUMBER [Primary Key]
var params = {
  sourceType: undefined /* STRING */,
  values: values /* INFOTABLE*/,
  source: undefined /* STRING */,
  tags: undefined /* TAGS */
me.AddOrUpdateDataTableEntries(params);
