Collection widget in Thingworx
csimhadri
I need to bind value to mashup parameter for Collection widget. How to bind source for the same
5 REPLIES 5
supandey
(To:csimhadri)
Hi @csimhadri not sure if I got your use case right. But if you are looking to bind parameters to mashup you'd need to select the Mashup Widget and then from the Data select the property that you want to bind with. Here's a very crude example where i have added  custom property of type boolean to the mashup and i am binding it to the another property of type boolean. See attached screenshots for reference.
Thank you @supandey for your quick response. Actually I'm looking for the solution to bind parameter which is coming from previous mashup. i.e. Mashup Parameter.
supandey
(To:csimhadri)
Well I think the process will remain the same, if this source mashup, i.e. the mashup from which you want to bring in the property value, is a contained mashup in your target mashup you can still select that mashup's property in the Binding Source
In case if this isn't a contained mashup, you can use this method defined in the article How to pass a parameter to a mashup from a hyperlink / URL in ThingWorx
PaiChung
22-Sapphire I
(To:csimhadri)
To pass values to your cells, you need to define a JSON
See the Help Center article.
http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/#page/ThingWorx%2FHelp%2FMashup_Builder%2FWidgets%2FCollectionWidget.html
KSM
(To:PaiChung)
Hi Pai,
Am successfully passing values to my cells, but am getting some blank rows on mashup when I scrolled up and down. what I found problem is the cell wont display the duplicate data on mashup. is it right? if not how could I resolve my problem. i have set UidField to unique identifier but some other data is having same like description alert type and etc.. so could you please help me out.
