Hi, I am working with a collection widget that shows some properties of different devices, I want to apply a custom style theme that can be set automatically to the red background when a property crosses its threshold, I have tried to give a condition through service but it sets the red background to all cards while I want it to some cards whose property crosses the threshold. so how can I do this?
If you want to change container color based on value, you can create custom CSS and expressions to dynamically pass CSS class to the container.
Step 1: Create custom CSS in child Mashup to change the background color of the container
/* Red Background Color */
.bgRed {
background: red;
/* Green Background Color */
.bgGreen {
background: green;
Step 2: Create expression function threshold value input
/* Condition based on your user case */
if(inputValue === "Alert")
Output = "bgRed";
} else
Output = "bgGreen";
Step 3: Bind the output of the expression to the container CustomClass property
Step 4: Remove the existing background color from Container
Now if you load the main mashup it will look like this
/VR
.bgRed {
background: red;
.bgGreen {
background: green;
Output = "bgRed";
} else
Output = "bgGreen";
/VR
