I am using TW 9.1. I have created a master with header blue color and a mashup in which the master is linked. When I run the mashup separately, its working fine. But when I navigate from some other mashup (with different master), the master header color is not applying it is getting replaced by white color and only if I reload the screen manually it is applying the blue color.
How can I resolve this issue?
Thanks in advance.
Hello @svisveswaraiya
pls check the linked article and let me know if this is siilar to the issue you are facing:
https://www.ptc.com/en/support/article/cs302094
Regards
Bhawna
Hello @svisveswaraiya ,
So as mentioned in the attached article this issue is fixed in 9.0 itself. Let me check if this is still present in 9.1
Regards
Bhawna
Hello @svisveswaraiya,
In such scenario pls report the case with the Support team or I can open a new case on your behalf.
https://www.ptc.com/en/support/article/cs67798
Regards
Bhawna
