Now I am creating daily reports(calculated values which carry numerical values) and writing them as .csv to send my team.
My team is located in Poland and Germany so their local setting in excel for numbers to carry decimal values is a comma'','' but Thingworx creating CSV with dots''.''
The issue is dots are not considered as numbers it considered as strings!!
Is there any way to resolve this ? or can we generate excel via service? or can I trigger the mashup widget(data export: which has generating excel file option) from the service?
Hi @sabharees
If you use the CSVParser extension, then https://www.ptc.com/en/support/article/CS237713 should help to change the field separator and decimal marker in the csv.
Regards
Christophe
Hi @sabharees
Regards
Christophe
