31-Aug-2017 14:42:54.112 信息 [localhost-startStop-1] org.apache.catalina.core.ApplicationContext.log No Spring WebApplicationInitializer types detected on classpath
31-Aug-2017 14:45:42.367 信息 [localhost-startStop-1] org.apache.catalina.core.ApplicationContext.log No Spring WebApplicationInitializer types detected on classpath
31-Aug-2017 14:45:43.429 严重 [localhost-startStop-1] org.apache.catalina.core.StandardContext.filterStart Exception starting filter HAAuthenticationFilter
javax.servlet.ServletException: java.security.KeyStoreException: Could not load keystore file.
at com.thingworx.security.authentication.HAAuthenticationFilter.init(HAAuthenticationFilter.java:49)
at org.apache.catalina.core.ApplicationFilterConfig.initFilter(ApplicationFilterConfig.java:279)
at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:260)
at org.apache.catalina.core.ApplicationFilterConfig.<init>(ApplicationFilterConfig.java:105)
at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:4700)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5340)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:145)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:753)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:729)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:940)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1816)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.security.KeyStoreException: Could not load keystore file.
at com.thingworx.platform.security.keystore.ThingworxKeyStore.loadExisting(ThingworxKeyStore.java:234)
at com.thingworx.platform.security.keystore.ThingworxKeyStore.load(ThingworxKeyStore.java:166)
at com.thingworx.platform.security.keystore.ThingworxKeyStore.getEntry(ThingworxKeyStore.java:207)
at com.thingworx.system.configuration.PlatformSettings.<init>(PlatformSettings.java:505)
at com.thingworx.system.configuration.PlatformSettings.getInstance(PlatformSettings.java:803)
at com.thingworx.security.authentication.HAAuthenticationFilter.init(HAAuthenticationFilter.java:36)
... 16 more
Caused by: java.io.IOException: Keystore was tampered with, or password was incorrect
at com.sun.crypto.provider.JceKeyStore.engineLoad(JceKeyStore.java:865)
at java.security.KeyStore.load(Unknown Source)
at com.thingworx.platform.security.keystore.ThingworxKeyStore.loadExisting(ThingworxKeyStore.java:231)
... 21 more
Caused by: java.security.UnrecoverableKeyException: Password verification failed
... 24 more
31-Aug-2017 14:45:44.085 严重 [localhost-startStop-1] org.apache.catalina.core.StandardContext.listenerStop Exception sending context destroyed event to listener instance of class com.thingworx.system.ThingWorxBootstrapper
java.lang.NullPointerException
at com.thingworx.system.ThingWorxBootstrapper.contextDestroyed(ThingWorxBootstrapper.java:342)
at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4900)
at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5537)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:221)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:149)
Can you provide more information? When you are receiving this error? Which ThingWorx version, which persistent provider, which Tomcat version?
Adam
Hi Guangyan, how is your platform-setting.json setup? are you using PostgreSQL? Is this a fresh installation or do you have configured SSL on existing Tomcat?
Your keystore and password are not working together .
Please check this article for resolution - https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS266176&lang=en_US
If you have already tried this or it's still giving same exception after trying this then let me know .
Thanks ,
Mukul Narang
