I need to integrate ThingWorx security with our Active Directory. I managed to connect to it using LDAP over port 389, tested it running the "GetDomainGroups" service and it returns all the groups in the defined branch from AD.
When I change the protocol to use LDAPS over port 636, and try to run the same service, I get an error: "Unable to Invoke Service GetDomainGroups on LDAPS : simple bind failed: servername:636".
I have a SSL certificate from my company (.pfx format) that I configured in Tomcat, so its running on https (i just copied the file into tomcat folder and configured the server.xml file to use it). Not sure if its there is anything else i should have done.
Konrad
Hello, Konrad.
First question; what version of ThingWorx are you running? 7.1.1 or later is needed for LDAPS support. Did it connect correctly on standard LDAP previously?
You followed the procedure of this article?
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS221840
-- Craig A.
Hi Craig,
I am using version 7.4, should be fine.
And it works fine for LDAP. I have 2 entities on my directory services, one for LDAP and one for LDAPS, and like I said, the only difference is the port number.
I did read that article, but it doesnt explain about the LDAPS piece.
Konrad
Any suggestions?
Can you please check the following?
The article covers LDAPS
Cannot connect to LDAP Server on port 389, 3268 and 636. | Knowledge Base | SonicWall
