Connect Error use ProtocolAdapterSDK
lvincent
I follow the protocol-adapter-user-guide.pdf , first i create an applicationKey like this:
keyId: da703fb6-a5e6-4a6f-b79a-641f8099c89f
and in the JavaCode , i fill the config.json like this:
"rows": [{
      "thingWorxServerUseSSL": false,
      "thingWorxServerAPIKey": "da703fb6-a5e6-4a6f-b79a-641f8099c89f",
      "thingWorxServerTimeout": 60000,
      "thingWorxServer": "120.25.75.77",
      "thingWorxServerPort": 8080
and
"rows": [{
      "socketPort": 11088,
      "connectionServerThingName": "myConnectionTestServer"
or so, in my linux-server, i allow port 11088 in iptable;
but when i run the "java -jar ProtocolAdapterSDK.jar", i got the Error in my Thingworx Monitor bellow
Error [authenticating connection], Server websocket will be closed. cause: invalid AppKey SecurityClaim provided
when run the java jar, it would not connect to the server, the log like this:
15:13:11.925 [Thread-0] DEBUG i.n.util.internal.PlatformDependent - sun.misc.Unsafe: available
15:13:11.927 [Thread-0] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noJavassist: false
15:13:11.933 [Thread-0] DEBUG i.n.util.internal.PlatformDependent - Javassist: unavailable
15:13:11.934 [Thread-0] DEBUG i.n.util.internal.PlatformDependent - You don't have Javassist in your class path or you don't have enough permission to load dynamically generated classes.  Please check the configuration for better performance.
15:13:11.934 [Thread-0] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.tmpdir: /tmp (java.io.tmpdir)
15:13:11.934 [Thread-0] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.bitMode: 64 (sun.arch.data.model)
15:13:11.934 [Thread-0] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noPreferDirect: false
15:13:11.968 [Thread-0] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.noKeySetOptimization: false
15:13:11.968 [Thread-0] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.selectorAutoRebuildThreshold: 512
15:13:12.010 [Thread-0] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numHeapArenas: 1
15:13:12.010 [Thread-0] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numDirectArenas: 1
15:13:12.010 [Thread-0] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.pageSize: 8192
15:13:12.010 [Thread-0] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxOrder: 11
15:13:12.010 [Thread-0] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.chunkSize: 16777216
15:13:12.010 [Thread-0] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.tinyCacheSize: 512
15:13:12.011 [Thread-0] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.smallCacheSize: 256
15:13:12.011 [Thread-0] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.normalCacheSize: 64
15:13:12.011 [Thread-0] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxCachedBufferCapacity: 32768
15:13:12.011 [Thread-0] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.cacheTrimInterval: 8192
15:13:12.028 [Thread-0] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - Initializing CommunicationEndpoint Connection Monitor...
15:13:12.034 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
15:13:12.035 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: EP_0, id: 0]. Attempting [re]connect...
15:13:12.035 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
15:13:12.035 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
15:13:12.100 [Client-EndpointMonitor-1] DEBUG i.n.util.internal.ThreadLocalRandom - -Dio.netty.initialSeedUniquifier: 0x9a4c82fc17e07926 (took 4 ms)
15:13:12.150 [Client-EndpointMonitor-1] DEBUG io.netty.buffer.ByteBufUtil - -Dio.netty.allocator.type: unpooled
15:13:12.155 [Client-EndpointMonitor-1] DEBUG io.netty.buffer.ByteBufUtil - -Dio.netty.threadLocalDirectBufferSize: 65536
15:13:12.297 [NettyClient-NIO-1] DEBUG io.netty.util.ResourceLeakDetector - -Dio.netty.leakDetectionLevel: simple
15:13:12.335 [NettyClient-NIO-1] DEBUG c.t.c.c.c.n.ThingworxClientConnectionHandler - WebSocket Channel is connected [is open: true]
15:13:12.341 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocketClientHandshaker13 - WebSocket version 13 client handshake key: KL2OOjzWUYVcCyHoNrj47Q==, expected response: FpRb4jPP3qs/bihgiMSeerboR/U=
15:13:12.357 [NettyClient-NIO-1] DEBUG io.netty.util.Recycler - -Dio.netty.recycler.maxCapacity.default: 262144
15:13:12.448 [NettyClient-NIO-1] DEBUG c.t.c.c.c.n.ThingworxClientConnectionHandler - [ClientHandler: 1656749904] Client websocket handshake is complete
15:13:12.452 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.ClientCommunicationEndpoint - Preparing new Connection Authentication Request: DispatchingClientEndpoint [id: 0, isConnected: false, open connections: 0, max connections: 1]
15:13:12.454 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.CommunicationEndpoint - Sending connection authentication message, waiting for response [sync key: 1, message: AuthRequestMessage [requestId: 1, endpointId: -1, sessionId: -1, method: AUTHREQUEST]]
15:13:12.462 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=24
15:13:12.464 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
15:13:12.464 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=106
15:13:12.464 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=8
15:13:12.464 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=69
15:13:12.514 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://localhost:8080/Thingworx/WS] failed : Connection authentication/registration FAILED
[cause: invalid AppKey SecurityClaim provided]]
15:13:12.514 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: EP_0, id: 0]
15:13:12.515 [NettyClient-NIO-1] DEBUG c.t.c.c.e.DispatchingClientEndpoint - RESPONSE received [endpoint id: 0, duration: 58] ResponseMessage [requestId: 1, endpointId: 152, sessionId: -1, code: STATUS_UNAUTHORIZED, multipart: false, packet #: 0, total packets: 0]
15:13:12.772 [main] INFO  c.t.c.c.t.f.FileTransferVirtualThing - Creating new MegaTrackerConnectionServerThing [name: SuhaiConnectionServer, logs: /root/., stagingPath: null]
Please who can help me ????
Li,
You created your Application Key in the server you are attempting to connect to correct?
Is this application something you've created or downloaded from somewhere?
Meghan
i create two application key, one for Android, one for JavaSDK. Android's Key word well, But the other no word. Do you had any Demo for me to run??
