Connect a device on an OPC server (KepserverEX) to Azure Cloud using OPC Publisher on Azure IoT Edge
Farouk-Louali
8-Gravel
Hello Community ,
Here is a video I made that goes over all parts of configuring industrial equipment connection on KepserverEX (v6.10.623) by exposing an OPC UA interface to the Azure cloud through the OPC Publisher module installed on Azure IoT Edge and make the telemetry of this equipment flow in Azure via Azure iot hub
Hope this helps many of you around the world who have struggled with this installation and configuration procedure.
https://www.youtube.com/watch?v=vV3ZEFO1O3s
Thanks & Regards,
Step by step tutorial to connect an industrial equipment exposing an OPC UA interface to the Azure cloud via the OPC Publisher module installed on Azure IoT Edge and make the telemetry of this equipment flow in Azure via Azure IoT Hub Create azure iot edge device ...
2 REPLIES 2
Thank you, @Farouk-Louali, for sharing this with the community!
--Sharon
Thank you @slangley  !
