Connect postgreSQL with ThingWorx
kqian-2
I have already installed postgreSQL,but I don't know which Thing Template should I chose when I create a Thing.
The version of postgreSQL I am using is 9.5
6 REPLIES 6
nkhose
(To:kqian-2)
kqian-2
(To:nkhose)
I am sorry that I don't have the permission to down the extension.
nkhose
(To:kqian-2)
That will be very straightforward , i wonder about the permission to down. the ext'n ,
you need to login/signup on the same .. if that is also not working , here is the link i have created you can download from here
https://mab.to/jiUFroljS
Thanks ,
Nilesh
kqian-2
(To:nkhose)
Hi Nilesh,
I have download from the link you created successfully.
Thanks a lot !
nkhose
(To:kqian-2)
Cheers !
Aanjan
(To:kqian-2)
Kitty, choosing a Thing Template would ultimately be dependent on what you're designing. GenericThing Template is our default/ base Template. If you are going for remote connections, we have a RemoteThing Template (which also has ones for file transfer and tunneling).
