i'm trying to start a thingworx analytics docker and when it's trying to connect to thingworx core i get the error on the image. Can anyone help me please.
I know it's related to WS(websockets) and something is blocking the requests, but i don't know how to deactive that block.
Thank you.
Hi, thanks for the help @cmorfin .
What i did to make this work was disable the ufw on ubuntu and it worked. No error is reported.
Thank you once again.
Thank you for posting to the PTC Community.
In order to assist you, I have some clarifying questions:
Neel
Thanks @nsampat.
Part of the issue you may be experiencing is a mis-match in version.
ThingWorx Analytics 9.0 requires ThingWorx Platform Server 9.0
Please either use Thingworx Analytics 8.5.1 or newer (up to TWA 8.5.7) with ThingWorx Platform Server 8.5, or update your ThingWorx Platform Server to 9.0 to use ThingWorx Analytics 9.0.
Information about compatibility can be found here: https://support.ptc.com/help/thingworx/analytics/r9/en/#page/analytics%2Fcompatibility%2Fthingworxanalytics_compatibility_8_5_later.html%23wwID0EMLQQ
Neel
Tested with thingworx foundation 9.0 and thingworx analytics 9.0 resulted in the same error.
Some additional items:
Neel
Hi.
Thank you @nsampat. I was following the thingworx docker tutorial.
Unfortunately, I am not familiar with the ThingWorx Docker Tutorial you have mentioned. Are you able to provide a link to what you are referring to?
Regarding your issue, can you verify that all the required ports are opened, and that the two containers are able to see each other?
https://docs.docker.com/engine/reference/commandline/port/
The error messages in the adapter.log you provided are stating that same thing,
ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://172.17.0.1:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
Are you using SSL deployment for ThingWorx?
If there is some urgency to this discussion, please note I am based in North America UTC -4. If you desire more direct assistance, the next step would be to open a case with our support team here: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
Neel
Hi, I don't have urgency for now.
I follow the tutorial inside the zip on thingworx dockerfiles -> ThingWorx-Foundation-DockerFiles-9-0-1 (6 MB)
https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=TWX
I not using SSL. As i stated before seems to me that thingworx is blocking WS requests. Maybe tomcat is blocking ?
Thank you @nsampat
My specialty is only with ThingWorx Analytics. Since you have indicated that the connection endpoint and ports are set correctly, I will have to ask for additional assistance to review what may be wrong with the connection.
@posipova or @slangley are you able to assist with ThingWorx Platform Server Docker deployments?
Neel
I did a test with ThingWorx 9.0 and ThingWorx Analytics 9.0 as docker and got initially the same error.
It appears this would be related to how docker interact with the firewall (at least it is in my case).
You can maybe run the following test to confirm if you have the same behaviour:
At this stage it works for me: the Analytics remote thing get created after a little why in ThingWorx.
Can you confirm if that works for you too ?
Obviously this would not be the right operational mode but it allows to pinpoint the issue. You would need then to find the right firewall/iptable configuration.
Hope this helps
Christophe
