Connecting DS18B20 to Thingworx
festes
I have modified 'AdafruitDHT.py' script from the tutorial to connect AM2302 sensor to thingworx, and used it to bind DS18B20 sensor.
Following is the script I have used to replace existing file in line 57 of 'TempAndHumidityThing':
import w1thermsensor
sensor = w1thermsensor.DS18B20
pin = '4'
temperature = w1thermsensor.read_retry(sensor, pin)
if temperature is not None:
print('Temp={0:0.1f}*C'.format(temperature))
    sys.exit(1)
It gives 'command not found' error
Can anyone please help?
5 REPLIES 5
supandey
(To:festes)
Hi Fred, not sure if this is the complete script, but it seems to be missing shebang something like this #!/usr/bin/env python or #!/usr/bin/env python3 . This goes at the very top of the file containing your python script.
You'll need this while executing the script from a shell to specify Python interpreter to be used
festes
(To:supandey)
Sushant, I have added shebang, but it is still giving the same error. Is there anything else that I'm missing?
supandey
(To:festes)
Could you also share which python version and on which OS are you attempting to execute this script? And also how are you executing it? Something  like ./<pythonFileName>.py
is the environment variable correctly set for python?
festes
(To:supandey)
I am using Python 2.7.9 and Unix. The command I'm using is:
java -jar ./temperature-thing-jar-with-dependencies.jar wss://xxxxx.vuforia.io:8443/Thingworx/WS 3c740dfe-df0e-4c85-8ceb-ee3ce7e2ec85
The tutorial to push simulated data to Thingworx worked. But altering the script to push real-time data from DS18B20 gives the error.
manten
2-Explorer
(To:festes)
I am trying to bind temperature sensor ( DS18B20 ) data to Thingworx platform. I need the script to push real time data from DS18B20   in to thingworx. could you please help me with this script.
