Connecting PTC Creo to ThingWorx server
adityak0195
6-Contributor
I am using Creo 4 M050 and Creo Product Insight for ThingWorx Extension 8.2.3. Currently facing an issue that I am not able to connect to ThingWorx server to retrieve sensor data from the server. When I click connect to server it shows error "Connection to ThingWorx server cannot be established"
We are using .
Followed all the steps and configured the config.pro file, but then too facing issues while connecting to ThingWorx server.
Also find attached the config.properties file where we are giving details like ThingWorx server, Administrator key etc.
Please help me with the solution.
Thanks and regards,
Aditya
cmorfin
(To:adityak0195)
Hi @adityak0195
For the record this has been resolved offline .
Steps are now documented at https://www.ptc.com/en/support/article?n=CS313678
Could you please mark this answer as correct so others may benefit form it.
Thank you
Kind regards
Christophe
adding config.properties file
cmorfin
(To:adityak0195)
Hi @adityak0195
Thank you
Kind regards
Christophe
adityak0195
6-Contributor
(To:cmorfin)
Thank you for your email.
adityak0195
6-Contributor
(To:cmorfin)
Thank you
