Connecting to Printer
ptc-6173930
Can we connect to a printer and print the current screen.
Thomas
smanley
(To:ptc-6173930)
Hi Thomas,
In order to print the mashup screen, you'll have to access the browser's print function. To do this, add the link widget to your mashup and in the
This helps Saeed.
Thomas
How we can use link widget for printing ? Can we print custom reports?
Aanjan
(To:pbelagali)
I believe he meant the 'print' button/ option available with browsers under the File menu. Another option would be to convert your mashups into pdf using one of the free html to pdf tools available online.
Did you cut off the rest of the explanation?  Your post says:
"In order to print the mashup screen, you'll have to access the browser's print function. To do this, add the link widget to your mashup and in the"
Is there a way to use the Link widget to call the browser's print function?  I'm trying to find a way to do that.
