We are trying to connect to a printer through a print server in ThingWorx to print a label.
We were wanting to know if anyone knew what the address format would be for this connection?
Hi @BS_9645881
Have you validated connectivity to the printer outside of ThingWorx using the unc path: \\PrintServer\PrinterName. Be sure to test it from the server running ThingWorx.
What error are you getting?
--Sharon
