I'm fairly new to Thingworx and trying to get some first steps done by connecting a Pi to Thingworx, following the
Raspberry Quickstart guide. (https://developer.thingworx.com/en/resources/guides/thingworx-raspberry-pi-quickstart/)
EMS is 5.4
I'm using a own thingworx installation.
First my config.json:
{ "ws_servers": [{ "host": "twxdemo.inneo.cloud", "port": 443 }], "http_server": { "host": "127.0.0.1", "port": 8080, "ssl":false, "authenticate":false }, "appKey": "xxx", "logger": { "level": "INFO" }, "auto_bind": [{ "name": "PiThing", "gateway": false, "host": "127.0.0.1", "port": 8001 }], "certificates": { "validate": false, "allow_self_signed":true }, "ws_connection": { "encryption": "ssl", "verbose": true, "msg_timeout": 1000 } }
It does connect:
pi@raspberrypi:~/microserver $ sudo ./wsems [FORCE] 2019-02-25 12:25:10,253 ./wsems: Initializing EMS .... [FORCE] 2019-02-25 12:25:10,253 main: Using config file /home/pi/microserver/etc/config.json [INFO ] 2019-02-25 12:25:10,254 ./wsems: Creating the WsEms proxy. [INFO ] 2019-02-25 12:25:10,254 ./wsems: Starting HTTP Server. [INFO ] 2019-02-25 12:25:10,254 Main: Using custom certificate and private key for HTTP Server [WARN ] 2019-02-25 12:25:10,254 Main: Encryption is disabled on HTTP Server. [WARN ] 2019-02-25 12:25:10,254 Main: Authentication is disabled on the HTTP Server. [INFO ] 2019-02-25 12:25:10,255 ./wsems: Initializing the ThingWorx REST interface. [FORCE] 2019-02-25 12:25:10,255 httpServer: starting http server port=8080 [INFO ] 2019-02-25 12:25:10,255 wsEmsProxy::initialize: FIPS is disabled. [INFO ] 2019-02-25 12:25:10,255 wsEmsProxy::initialize: Encryption is enabled on Web Socket connection. [WARN ] 2019-02-25 12:25:10,257 SDK: SDK Version: 2.0.4 [WARN ] 2019-02-25 12:25:10,257 SDK: TLS Library: OpenSSL [WARN ] 2019-02-25 12:25:10,257 SDK: TLS Library Version: 1.0.2l [WARN ] 2019-02-25 12:25:10,257 SDK: FIPS Capable [INFO ] 2019-02-25 12:25:10,277 WsProxy::initialize: EMS Version 5.4.0.114 [INFO ] 2019-02-25 12:25:10,277 WsProxy::initialize: twApi singleton initialized [WARN ] 2019-02-25 12:25:10,278 WsProxy::initialize: Certificate validation is disabled. [WARN ] 2019-02-25 12:25:10,278 WsProxy::initialize: Self signed certificates are enabled. [ERROR] 2019-02-25 12:25:10,279 SDK: twMap_Add: parse function returned null. [INFO ] 2019-02-25 12:25:10,279 wsEmsProxy::initialize: Initialization complete! [INFO ] 2019-02-25 12:25:10,281 ./wsems: Starting the connection. twxdemo.inneo.cloud:443-->[INFO ] 2019-02-25 12:25:10,356 SDK: twWs_Connect: Websocket connected! [WARN ] 2019-02-25 12:25:10,478 SDK: twBindBody_Delete: NULL body or stream pointer [INFO ] 2019-02-25 12:25:10,482 Main: Succesfully connected. Saving .booted config file
However runing the LUA script does result into it beeing stuck at crating a new handler(EMS does run):
pi@raspberrypi:~/microserver $ sudo ./luaScriptResource [INFO ] 2019-02-25 12:24:34,835 ./luaScriptResource: Using config file: /home/pi/microserver/etc/config.lua [FORCE] 2019-02-25 12:24:34,835 ./luaScriptResource: Starting up .... [INFO ] 2019-02-25 12:24:34,840 luaScriptResource:main: Encryption is disabled on the RAP connection. [INFO ] 2019-02-25 12:24:34,840 luaScriptResource:main: FIPS is disabled. [INFO ] 2019-02-25 12:24:34,843 ./luaScriptResource: New path is /home/pi/microserver/etc/thingworx/clibs:/home/pi/microserver/etc/custom/clibs:/home/pi/microserver/etc/community/clibs:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin [WARN ] 2019-02-25 12:24:34,846 ScriptResource::initialize: Encryption is disabled on HTTP Server. [WARN ] 2019-02-25 12:24:34,846 ScriptResource::initialize: Authentication is disabled on the HTTP Server. [FORCE] 2019-02-25 12:24:34,876 httpServer: starting http server port=8001 [INFO ] 2019-02-25 12:24:34,893 thingworx.shape: Creating a new shape. [INFO ] 2019-02-25 12:24:34,895 PiThing: -- Configuration ------------------------------- [INFO ] 2019-02-25 12:24:34,895 PiThing: scanRate: 1000 [INFO ] 2019-02-25 12:24:34,895 PiThing: scanRateResolution: 500 [INFO ] 2019-02-25 12:24:34,896 PiThing: taskRate: 30000 [INFO ] 2019-02-25 12:24:34,896 PiThing: keepAliveRate: 60000 [INFO ] 2019-02-25 12:24:34,896 PiThing: requestTimeout: 15000 [INFO ] 2019-02-25 12:24:34,896 PiThing: registerRate: 43200000 [INFO ] 2019-02-25 12:24:34,896 PiThing: register: true [INFO ] 2019-02-25 12:24:34,896 PiThing: getPropertySubscriptionOnReconnect: false [INFO ] 2019-02-25 12:24:34,897 PiThing: maxConcurrentPropertyUpdates: 100 [INFO ] 2019-02-25 12:24:34,897 PiThing: defaultPushType: VALUE [INFO ] 2019-02-25 12:24:34,897 PiThing: useShapes: true [INFO ] 2019-02-25 12:24:34,897 PiThing: identifier: Not Specififed [INFO ] 2019-02-25 12:24:34,897 PiThing: ------------------------------------------------ [INFO ] 2019-02-25 12:24:34,898 thingworx.template: Adding shape 'shapes.metadata' to template 'thingworx.template' [INFO ] 2019-02-25 12:24:34,899 thingworx.template: Adding shape 'shapes.propsubscribe' to template 'thingworx.template' [INFO ] 2019-02-25 12:24:34,899 thingworx.template: Creating new templates.PiTemplate named 'PiThing' [INFO ] 2019-02-25 12:24:34,899 PiThing: -- Initializing properties --------------------- [INFO ] 2019-02-25 12:24:34,899 PiThing: Initialized property cpu_temperature [baseType: number, pushType: ALWAYS, handler: nil, value: 0] [INFO ] 2019-02-25 12:24:34,899 PiThing: Initialized property temp [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0] [INFO ] 2019-02-25 12:24:34,900 PiThing: Initialized property humidity [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0] [INFO ] 2019-02-25 12:24:34,900 PiThing: Initialized property cpu_volt [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0] [INFO ] 2019-02-25 12:24:34,900 PiThing: Initialized property upToDate [baseType: BOOLEAN, pushType: NEVER, handler: nil, value: true] [INFO ] 2019-02-25 12:24:34,900 PiThing: Initialized property cpu_freq [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0] [INFO ] 2019-02-25 12:24:34,900 PiThing: ------------------------------------------------ [INFO ] 2019-02-25 12:24:36,870 PiThing: -- Starting script -------------------------- [INFO ] 2019-02-25 12:24:36,870 PiThing: Registering core callback handler [INFO ] 2019-02-25 12:24:36,870 PiThing: Starting main loop [INFO ] 2019-02-25 12:24:36,870 PiThing: Calling lifecycle start listeners. [INFO ] 2019-02-25 12:24:36,871 shapes.propsubscribe: Initialized [INFO ] 2019-02-25 12:24:36,872 thingworx.handler: Creating a new handler.
In Thingworx the PiThing is connected but without the Properties like cpu_temperature e.g.
here config.lua file
scripts.log_level = "INFO" scripts.script_resource_ssl = false scripts.script_resource_authenticate = false scripts.PiThing = { file = "thing.lua", template = "PiTemplate", scanRate = 1000, taskRate = 30000 } scripts.rap_host = "127.0.0.1" scripts.rap_port = 8080 scripts.rap_ssl = false scripts.script_resource_host = "127.0.0.1"
and the edited PiTemplate.lua
module ("templates.PiTemplate", thingworx.template.extend) properties.cpu_temperature = {baseType="number", pushType="ALWAYS", value=0 } properties.cpu_freq = {baseType="NUMBER", pushType="ALWAYS",value=0 } properties.cpu_volt = {baseType="NUMBER", pushType="ALWAYS", value=0 } properties.temp = { baseType="NUMBER", pushType="ALWAYS", value=0 } properties.humidity = { baseType="NUMBER", pushType="ALWAYS", value=0 } serviceDefinitions.GetSystemProperties( output { baseType="BOOLEAN", description="" }, description { "updates properties" } ) -- service input parameters -- me: table that refers to the Thing -- headers: table of HTTP headers -- query: query parameters from the HTTP request -- data: lua table containing the parameters to the service call. services.GetSystemProperties = function(me, headers, query, data) log.trace("[PiTemplate]","########### in GetSystemProperties#############") queryHardware() -- if properties are successfully updated, return HTTP 200 code with a true service return value return 200, true end function queryHardware() -- use the vcgencmd shell command to get raspberry pi system values and assign to variables -- measure_temp returns value in Celsius -- measure_clock arm returns value in Hertz -- measure_volts returns balue in Volts local tempCmd = io.popen("vcgencmd measure_temp") local freqCmd = io.popen("vcgencmd measure_clock arm") local voltCmd = io.popen("vcgencmd measure_volts core") local sensorCmd = io.popen("./Adafruit_Python_DHT/examples/AdafruitDHT.py 11 4") -- set property temperature local s = tempCmd:read("*a") s = string.match(s,"temp=(%d+\.%d+)"); log.debug("[PiTemplate]",string.format("temp %.1f",s)) properties.cpu_temperature.value = s -- set property frequency s = freqCmd:read("*a") log.debug("[PiTemplate]",string.format("raw freq %s",s)) s = string.match(s,"frequency%(45%)=(%d+)"); s = s/1000000 log.debug("[PiTemplate]",string.format("scaled freq %d",s)) properties.cpu_freq.value = s -- set property volts s = voltCmd:read("*a") log.debug("[PiTemplate]",string.format("raw volts %s", s)) s = string.match(s,"volt=(%d+\.%d+)"); log.debug("[PiTemplate]",string.format("scaled volts %.1f", s)) properties.cpu_volt.value = s -- set property temp and humidity local sensor = sensorCmd:read("*a") log.debug("[PiTemplate]",string.format("raw sensor %s", sensor)) s = string.match(sensor,"Temp=(%d+\.%d+)"); log.debug("[PiTemplate]",string.format("scaled temp %.1f", s)) properties.temp.value = s s = string.match(sensor,"Humidity=(%d+\.%d+)"); log.debug("[PiTemplate]",string.format("scaled humidity %.1f", s)) properties.humidity.value = s end tasks.refreshProperties = function(me) log.trace("[PiTemplate]","~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ In tasks.refreshProperties~~~~~~~~~~~~~ ") queryHardware() end
did I miss sth. at the PiTemplate.lua?
Any help appreciated!
Solution:
Step1:
Update the EMS to 5.4.1 or higher.
link in Guide refers to 5.4.0 which causes the Problem.
just Download the latest Version from PTC.
Step 2:
in the PiTemplate.Lua
is a Typo:
it needs to be changed into NUMBER.
Hi @MHaas1.
Did you set up the bindings in ThingWorx (step 10 from the instructions)? Until you have bound the entity/properties with the corresponding ones from your remote thing, you won't see anything in ThingWorx.
--Sharon
Hi Sharon,
Thats where i get stuck. Below a Screenshot from "Manage Bindings" Button.
after some time the "Service GetRemoteMetadata has timed out" Message appears.
Regards
Moritz
*Edit1: Screenshot
Solution:
Step1:
Step 2:
is a Typo:
