Hi All,
My connection with trial version thingworx composer are being refused.
I think the connection got blocked or something...
Any tips?
A.
Seems by not using the launch button and rather paste the url in your browser does the trick.
Some data could be cached that causes the issue. I have to do these steps when I work from another location besides the location I registered.
Hi @AnselmoSilSaito sorry to hear that you are not able to connect. Are you also not able to access your trial instance? Could you share with me the URL to test it out?
It is unstable. It may fall anytime.
That's my URL and it's currently off:
pp-1802191911zu.devportal.ptc.io
Can you log in at developer.thingworx.com and click the "server" icon in the top right?
When there is no activity, your server is paused and must be restarted
Even if I do that, the problem still happens.
What happens when you click on this link:
https://pp-1802191911zu.devportal.ptc.io/Thingworx/Home
You should see a login prompt. Enter username:
Administrator
Copy your password by clicking on the server icon on developer.thingworx.com
My error change to "ERR_CONNECTION_TIMED_OUT" ...but my connection is pretty decent.
Do you see that when you go to developer.thingworx.com, or when you click on the server icon, or when you clicked on the link to your server in my previous message?
Seems by not using the launch button and rather paste the URL in your browser does the trick.
Some data could be cached that causes the issue. I have to do these steps when I work from another location other than the location I registered.
