Is there any possibility to modify connection strings (which are present in the configuration in a thing) dynamically.
Surekha N.
Yup ,using the ConnectionInfo configuration table of DB thing you can do that .I am already aware about the received solution to you through the support case .
Request you to accept this solution if it worked for you .
Thanks ,
Mukul Narang
Are you referring to change the connection string of a DB thing dynamically ? What is the use case here ?
Mukul Narang
Hi @mnarang ,
Thank you for your reply. In my application, we are saving data into separate gdb files(Firebird database) daily, so I need to modify connection string dynamically. Now I got a solution by modifying the SetConfigurationTable.
Surekha N.
Thanks ,
Mukul Narang
