Connection string modification
  • February 9, 2019
  • 1576 views
Is there any possibility to modify connection strings (which are present in the configuration in a thing) dynamically.
Surekha N.
Best answer by mnarang
Yup ,using the ConnectionInfo configuration table of DB thing you can do that .I am already aware about the received solution to you through the support case .
Request you to accept this solution if it worked for you .
Thanks ,
Mukul Narang
Are you referring to change the connection string of a DB thing dynamically ? What is the use case here ?
Mukul Narang
Surekha1-VisitorAuthor
Hi @mnarang ,
        Thank you for your reply. In my application, we are saving data into separate gdb files(Firebird database) daily, so I need to modify connection string dynamically. Now I got a solution by modifying the SetConfigurationTable.
Surekha N.
mnarang5-Regular MemberAnswer
Thanks ,
Mukul Narang
