Team - Good day!
I'm getting below error; Looks like firewall issue from device(our) side; But would like to check with you guys-Experts. Version details: SDK 2.0.4, EMS 5.4:
Thanks for the support and look forward to hearing from you:-)
[FORCE] 2018-04-18 22:13:58,318 ./wsems: Initializing EMS ....
[FORCE] 2018-04-18 22:13:58,318 main: Using config file /home/pi/Downloads/microserver/etc/config.json
[INFO ] 2018-04-18 22:13:58,318 ./wsems: Creating the WsEms proxy.
[INFO ] 2018-04-18 22:13:58,318 ./wsems: Starting HTTP Server.
[INFO ] 2018-04-18 22:13:58,318 Main: Using custom certificate and private key for HTTP Server
[WARN ] 2018-04-18 22:13:58,318 Main: Encryption is disabled on HTTP Server.
[WARN ] 2018-04-18 22:13:58,318 Main: Authentication is disabled on the HTTP Server.
[FORCE] 2018-04-18 22:13:58,319 httpServer: starting http server port=8080
[INFO ] 2018-04-18 22:13:58,319 ./wsems:
[INFO ] 2018-04-18 22:13:58,319 wsEmsProxy::initialize: FIPS is disabled.
[DEBUG] 2018-04-18 22:13:58,319 httpServer: http server bound to port=8080.
[INFO ] 2018-04-18 22:13:58,319 wsEmsProxy::initialize: Encryption is enabled on Web Socket connection.
[WARN ] 2018-04-19 03:43:58,321 SDK: SDK Version: 2.0.4
[WARN ] 2018-04-19 03:43:58,321 SDK: TLS Library: OpenSSL
[WARN ] 2018-04-19 03:43:58,321 SDK: TLS Library Version: 1.0.2l
[WARN ] 2018-04-19 03:43:58,321 SDK: FIPS Capable
[DEBUG] 2018-04-19 03:43:58,321 SDK: twWs_Create: Initializing Websocket Client for PP-18042606269R.devportal.ptc.Io:443//Thingworx/WS
[DEBUG] 2018-04-19 03:43:58,321 SDK: twTlsClient_Create: Initializing TLS Client
[DEBUG] 2018-04-19 03:43:58,371 SDK: twTlsClient_Close: Disconnecting from server
[ERROR] 2018-04-19 03:43:58,371 SDK: twWs_Create: Error creating BSD socket to be used for the websocket
[ERROR] 2018-04-19 03:43:58,371 SDK: twApi_Initialize: Error creating websocket structure, retrying
[DEBUG] 2018-04-19 03:44:03,371 SDK: twWs_Create: Initializing Websocket Client for PP-18042606269R.devportal.ptc.Io:443//Thingworx/WS
[DEBUG] 2018-04-19 03:44:03,371 SDK: twTlsClient_Create: Initializing TLS Client
Hi @pponraj it appears to be similar to this thread here CSDK Connnection issue. Even though the thread is for C SDK but it appears that your issue is more related to the platform itself than with the EMS.
