pshashipreetham
18-Opal
18-Opal
January 8, 2022
Contained Mashup Widget Issue in 9.3
  • January 8, 2022
  • 2508 views
As per below picture, the Mashup is center aligned, when there mashup is selected in the Contained mashup.
When a Mashup is selected in Name widget property of the Contained mashup, total Mashup/Container goes to left top.
As per the use case, when an Mashup is selected in the Name Widget Property of Contained Mashup, whole mashup should be still center aligned.
Thingworx version: 9.3
Contained Mashup is Palced inside a Field Set.
@slangley@c_lowy@VladimirN  @CarlesColl
Shashi
Best answer by pshashipreetham
Hi @slangley ,
Raised an PTC case, this is what they responded:
This is a bug in 9.3.
Shashi.
Support
January 20, 2022
Hi @pshashipreetham.
It appears you're using a static mashup.  Are you seeing the shift in the preview?  Once you view it, does it still show shifted?
You could try using a responsive mashup and then in the Layout tab, change the Positioning to static.  Scroll down for setting the container size.
Regards.
--Sharon
pshashipreetham
18-Opal
18-Opal
January 22, 2022
Hi @slangley ,
Thanks for the reply, the screenshots posted (in the first post) are done in the exactly in same process in which you have guided. Still the issue exists.
Shashi.
Shashi Preetham || +91 8099838801
