Convert blob data to String ( and vice versa )
Yoshihiko.N
Hi Developers,
I'd like to convert blob data to string and convert to string data to blob.
may I get your help to do the above ?
let blob_data = LoadBinary( { path : "/image.png" } );
//convert blob data to string to write it to SQL
let str_data = {something function for the conversion}
Rocko
(To:nmutter)
The "trick" is SaveBinary accepts base64 encoded values for content as shown in https://www.ptc.com/en/support/article/CS212085.
Check here for an example.
8 REPLIES 8
Hey,
normally you would use base64 functions to achieve this. Use Encode to convert to string and decode to return to binary. But I could not get it to work as I would like.
Maybe the ptc article https://www.ptc.com/en/support/article/CS335717 helps as some starting point.
They use the snippets available in Composer:
Yoshihiko.N
(To:nmutter)
Hi
Thank you for your response.
I've created a test service to check if the resolution in the link you shared with me, but failed.
I expected to get original image but image data cannot be  restored.
I'd be happy someone help me on this.
Yes that's where I had the issue too. But you see in line 12 it changes your binary data and wraps {array:xxx} around it.
After decoding you would need to reverse this operation as well, to get only your xxx back. But I did not try it further for now
Yoshihiko.N
(To:nmutter)
Hi
Tahnk you for quick response.
I tried with the coding below but failed.
is there any miss there ?
Yoshihiko.N
(To:Yoshihiko.N)
Hi All,
I'd be happy if someone help me to know is there any miss in my code the above.
I think thingworx wants you to write it to a repository first.
Things["FileServerRepository"].SaveBinary({
path: "your path here") /* STRING */,
content: blobOriginal /* BLOB */
and from there you can do:
var result = Things["SystemRepository"].LoadImage({path: "your path here"})
That is what i did. and afterwards you van delete the image again.
I also tried to get the code running. But the issue is that the LoadBinary returns an "object" of type "BlobPrimitive". But I am not able to create an instance of that type "Blob" after decoding the string back to binary. I just have a json-array which TWX does not interprete as BLOB.
So what our service does is:
- LoadBinary -> Blob -> JsonArray -> Base64Encode -> String
- String -> Base64Decode -> JsonArray -x> Blob -> SaveBinary
But for the red part I do not have a solution...
TWX needs to have the blob-type for it to work. I did not find a way to create such an object in JavaScript code... No solution so far (Java Extension should work but this would be not so nice as workaround)
Rocko
(To:nmutter)
