Corresponding Starting/closing bracket is not shown if lines of code in between is >= 100
rkandasamy
7-Bedrock
Hi Team,
When used to write more number of lines of code in thingworx based our need/requirements.we observed that closing/Starting bracket is not shown correspondingly if the lines of code between them is  equal or greater than 100 lines.
If you could resolve this, it would be helpful.
Thanks.
6 REPLIES 6
Hi Rdhakrishnan Kandasamy​ Thank-you for bringing to us , which you thing could be a potential bug. Please help us understand the problem .
Please explain in little detail what you are saying  , like , are you pointing to , while writing services or some Extension development code.
Please share screenshot as well. Your help would greatly be appreciated if shared with Steps of replication along with version of Thingworx , you are quoting here.
Thank you once again !
Ravi Upadhyay
Hi Ravi,
i am using thingworx version 7.1.0-b484. I am seeing this problem while writing thingworx service code(javacript).
To Replicate:
Open any thing and add a new service and inside that:
If( 2 == 2)
logger.info("Two is equal to two");
Now just try increasing the number of lines as empty lines between open/close bracket till reaches more than hundred. So the corresponding start/close bracket won't be highlighted after 100 line count.
Thanks.
Rdhakrishnan Kandasamy​,
I can reproduce this issue. Can you please open case with PTC TS to report it to R&D.
Ankit Gupta
Rdhakrishnan Kandasamy​ I have opened Jira PSPT-2976 for this issue. Just open a case with PTC TS and ask the TS to link this Jira to receive updates on this Jira.
Hi Rdhakrishnan Kandasamy​,
On which ThingWorx version you are o?. Can you please share a Screenshot of what you mean.
I tried to create a service with if statement containing more than 100 lines of JavaScript code and I can see the start/closing bracket in ThingWorx 7.2.3.
Ankit Gupta
Thank-you for sharing the replication steps. Will try to reproduce on exactly same build and will inform you about my findings on this. If its bug , we will report to our Development team.
Thank-you once again for taking out time and reporting this to us. Highly appreciated.
On a slightly different note , have tried this on some different development IDEs , is it working okay there ?
