Dear all,
If I build the data analysis model in Python or Matlab, could I use the new input data from thingworx and do prediction with the data analysis model from Python or Matlab, finally show the prediction result in thingworx mashup?
How does Thingworx work with other data analysis model built in Python or C/C#? Any example?
Thanks a lot
Hi @Dai-2006
Thank you for open this post on community.
Yes, you can use the model in ThingWorx Analytics. You need to convert that model into PMML form first, ThingWorx Analytics only except PMML form of model. Below are the link of one community post and an article for the same.
1) POST
2) Article
Hope this help, Do let me know in case of any question.
Hi @Dai-2006
1) POST
2) Article
Dear mgoel,
Thanks a lot for kind reply. I have yet check the solution due to other projects on hand. I will try according to the linked post.
