Deploying R Model in ThingWorx
  • July 25, 2018
  • 4130 views
I have working Machine learning Model developed in R studio. I need to deploy that code in ThingWorx platform.
Could you please help me in finding options for this?
Vamsi
Best answer by pshubham
To close this community thread:
@Vamsiakula: would you mind marking this response as a solution in order to close the community thread. Thanks!
Regarding the Docker Container in ThingWorx Analytics
It is not supported as of now. You can also refer to this article.
Regarding the pmml query
Kindly refer to this article provided by Mohit in the above reply.
Best Regards,
Prakhar Shubham
Hi Vamsi,
I request you to go through this article and confirm if this is what you are seeking.
Thank you
Best Regards,
Prakhar Shubham
Thanks for your response Prakhar Shubham. I will check this PMML option.
Another point I have is, I have created a docker container Image of the R model.
can ThingWorx analytics support docker container image? if yes, how to use Containers in ThingWorx.
Vamsi
Hi Vamsi,
Can you please clarify the part where you said that 'I have created a docker image container of the R model'. It would be great if you can just elaborate a bit around this.
Best regards,
Prakhar Shubham
