Could not load **Master", Reason 500, Could not create a transaction to Thingworx Persistance provider
ydai
1-Newbie
Hi all,
Do you meet this error? "Could not load **Master", Reason 500, Could not create a transaction to Thingworx Persistance provider. I open the Application.log and find the detail. How to solve this problem? Many Thanks.
8 REPLIES 8
supandey
(To:ydai)
Hi Yijun, seems like connectivity issue to PostgreSQL. Are you able to perform other tasks in Composer e.g. creating/editing a Thing? Does the issue persist despite the Tomcat restart? Can you check and share the tomcat's catalina.log file here? Is ThingWorx and Postgresql running on different machines?
ydai
1-Newbie
(To:supandey)
I didn't use the PostgreSQL. There are some properties' values will be deleted when 12:00 p.m. So I call the Timer5s services as a subscription.
The issue will be disappeared if I restarted the Tomcat.  I connect the Thingworx with MySQL server. But they are in the same machines.
I check the initial memory pool and maximum memory pool of Apache Tomcat 8.0 Properties (Java). They are none. By the way, I didn't set the Java options.
If I set the java options as the following, I cant start the Tomcat. It will shut down automatic.
-Dserver -Dd64
-XX:+UseNUMA
-XX:+UseConcMarkSweepGC
-Dfile.encoding=UTF-8
So, how to solve this problem?
Thanks a lot.
supandey
(To:ydai)
Hi Yijun, when you restart with those Java options what error message do you get in the Tomcat's catalina log? I think that needs to be fixed since we need those options for Tomcat. BTW, are you defining Xms and Xmx for the tomcat JVM?
ydai
1-Newbie
(To:supandey)
Hi Sushant, the catalina error logs are showed above. Today's log has no error.
supandey
(To:ydai)
Yijun, but these errors are from 5th Sept, are these same even when you add all the JAVA options for the Tomcat?
ydai
1-Newbie
(To:supandey)
I am out of office those days. I got the error messages from my colleague. I come back and change some JAVA options today. Just like add/delete :
-Dserver -Dd64
-XX:+UseNUMA
Delete the Initial memory pool and Maximum memory pool. But when I open the ThingWorx again, IE browser oops, and Chrome tells me that no memory. Just I post in another discussion. (IE browser looks oops)It looks so unreasonable. I don't know what happen. Looking forwards to your reply.
supandey
(To:ydai)
Thank you Yijun, I'll have look at the logs you have shared. Will check and get back to you.
ydai
1-Newbie
(To:supandey)
By the way, I didn't set/ define Xms and Xmx for tomcat JVM.
I just do some setting as the following
