In the attached code line no 282, i used state definition to highlight row based on the value present in highlight field of infotable. But it doesnt made any changes in tree grid.
Any idea on this ?
Hi @AP_10343008
Could you please post some screenshot and actual configuration json instead of complete js code
/VR
Still issue is not resolved. This is the config json which is passed to grid.
ThingWorx 9.1.0-b10877
Hello @AP_10343008,
If possible, could you please provide all sample entities (.xml files) to reproduce this issue? Also, provide the screenshot that identifies what does not display correctly in tree grid.
Hello @AP_10343008,
I am following up on your post.
Were you able to resolve this issue by yourself? If so, would you be comfortable posting the solution in the community and marking it as the accepted solution for the benefit of other community members?
Also, if you still have any questions/concerns/facing any issues, please let the community know so we can continue to support
Abhi
Hello @AP_10343008,
Could you please provide the information requested by @Velkumar?
Also, please check the browser's developer console for any JavaScript errors or warnings that might indicate issues with the conditional styling or other parts of the code.
Abhi
