I want to create DataTable Thing from extension. Also i want to add and delete records in DataTable Thing from ThingWorx extension. Is there any sample code available ? or help page which i can refereed ?
Ramesh, I have the same questions as you and would like to see a brief sample of Java code.
To create a DataTable thing in an extension use the "New Thing Template" creator button from the ThingWorx Eclipse extension and then change the "extends Thing" portion to "extends DataTableThing". This can be done with any type of ThingTemplate you want to implement.
