Create ICON from jpeg image
cgoma
I have jpeg image. I want to create icon using that image. The icon I will be using for sub menus
There's actually a field called ICONmaxWidth you can use, that could change the size.
zyuan1
18-Opal
(To:cgoma)
There is an ICON selection field when you create new Menu items, and it accepts Media entity, so just use your Jpeg image to create a Media would work.
cgoma
(To:zyuan1)
Hi @zyuan1
Thanks for your reply.
I had tried using the media entity. But the icon size for menu is showing as very small as attached icon-small.JPG
zyuan1
18-Opal
(To:cgoma)
This Cat image is the largest area an icon could reach
